In nova scotia with a street pilot iii. It told me the closest gas was something like 5 km north. Unfortunately, there was ocean in the way so that was something like eight hours away by road.Two problems I have with using a GPS to find a gas station. My old one assumed all convenience stores are at gas stations. Secondly they list the nearest in As-the-crow-flies miles. The station is only 2 miles away but you have to ride 10 miles along a river to find a bridge.
I carried a 5 liter plastic jerry can in the side-bag of my Sportster as it had a small tank. I never used it but it was one less thing to worry about while riding.
Needs vapour space to keep pressure under control. Now, given that bottle is designed to be actually pumped up and pressurized, I wouldnt be as concerned as with a plastic bottle that may split. Also, if you wanted to use it as a pressurized fuel bottle and had almost no head space, pressure would plummet and you'd be constantly pumping (similar to an air compressor with a tiny reservoir).It arrived, looks sturdy and well built,
Curious why this line insists on not filling above it
A little late to the party.
The msr fuel bottle is a decent option, but won't get you far.
Rotopax is the way to go. Slide it in a saddle bag, or buy/build a rack over your back seat.
This ones 1 gallon. 3.78L. Any smaller seems useless.![]()
I wonder how likely gas stations would shut off the pump, if they saw you filling one of those. Pretty sure they don't meet legal standards for carrying fuel. Red (or yellow for diesel)DSP has a line of foldable fuel containers.
Edit: Evoex already posted this.Giant Loop Armadillo Bag | Dualsport Plus
Introducing Armadillo Bag™, flexible, collapsible, lightweight, expedition-ready utility bladders for the safe transport and storage of liquid hydrocarbon products and other powersports and automotive fluids, available in 1-, 2-, 3- and 5-gallon sizes. Includes pour spout.www.dualsportplus.com
I've had them shut down pumps when I was filling Jerry cans on my truck tailgate... got to fill them on the ground.
in stock and free shippingDSP has a line of foldable fuel containers.
Static or some ****.I never understood why that is. When filling a vehicle, its gas tank isn't touching the ground.
The can ignite from the static between the bed liner and can Fire Hazard from Filling Portable Gas Cans in Pickup Trucks and Cars | NIOSH | CDCI never understood why that is. When filling a vehicle, its gas tank isn't touching the ground.
Sent from the future
I've heard that before, but I still don't get it. The entire vehicle is isolated from the ground by rubber, so how is that any different from filling the onboard gas tank?
Because when you are no longer in the vehicle, you are a travel path for static to discharge, coupled with plastic fuel jerry cans sitting on carpet or plastic bedliners in trucks are well known to collect static electricity.
Onboard gas tank has a system that discharges the static to the pump safely when the nozzle touches the metal filler neck. It may not do the same to a plastic jerry can sitting in a vehicle, so the best bet is to put it on the ground and ensure it discharges that way instead.
Plus, I think there's an element of "if it does burst into flames it's easier to deal with if it's on the ground outside the car vs lighting the entire car on fire".
Id think of it being the same likelihood of you exploding a gas pump by using your cellphone in close proximity.I still don't see it. Let's say the plastic gas can in my trunk is bouncing around and rubbing itself all over the carpet and building up static electricity on my way to the gas station. What's the first thing I do when I arrive? Open the trunk and grab the can. Any static would be discharged at this point. Now if you're going to be an idiot and use one hand to rub the jerry can around the carpet while filling with the other, then all bets are off. But maybe those are the people the rule is for...
In any case, if the metal filler neck of the gas tank is what dissipates the static, then there should also be no problem filling a bike in the back of the bed (or in my case, inside my van when I had it) - if your bike has a metal tank.
