What did you strip? the head on the drain plug? or the threads in the oil pan?
Can you get Vicegrips on it?
Lots of options and threads about this: http://www.gtamotorcycle.com/vbforum/search.php?searchid=358839
Helicoil should fix you right up.
what about metal shavings going inside the pan ?
is the pan siliconed ? because it doesnt want to come off, does it need a gasket as well ?
hey I just picked up some spark plug helicoil M14-1.25 , there was the drain plug helicoil repair hit as well but more expensive, but the thing looks identical. Quick question tho, which size drill bit should I use to clean the whole 14 mm ?
nope it wont. i have had 2 bikes come into my shop with helicoils in them and a oil leak .you have to replace the pan or go next size up on the bolt..next time dont tighten the bolt untill it goes loose..bobo.Helicoil should fix you right up.
