Voltage means **** all. It's all about current. Apply power directly to the starter when it refuses to crank, see if that makes any difference. If it does, than apply power to battery and try it.
Since you're so argumentative I'll let you figure it out...
Fortunately I have found the problem, I know that these bikes are weak in the electrical department and one guy that ha one needed to run a new ground through his entire wiring harness before his problem was resolved. Thanks for your input though.I have the same bike. I would start looking at your ground. Once its hot and zcts up, run a booster cable from the batt negative to the engine block and try that.
