Relax
If you do it yourself, you should be able to get an 8500 for ~500, if you want wifi and some other doodads, 8500w is ~100 more. Although an outlet should be installed close to the opener, many openers have been run on extension cords for decades with no issues. It is in an area where the cord is not subject to physical damage.
Yup, I installed mine myself and it was a snap. Way easier than a typical opener.
By the way, you’re supposed to detach the opener and check that the counterweight springs are able to hold the door open every once in a while or you will end up damaging the opener. That’s for all openers.
