TK4
What about olive oil ? Lots of you have Italian motorcycles ????
The TS always puzzles me - she asks for blue oil."Present: DL650XT, SP125, TS125, FJR, GL1000, XV920R, TR25W"
That is kind of an open ended question, exactly which bikes are we talking about here and what oil specifications do the owner manuals call for ?
... correct answer is likely: the same length of time as any other correct combination of oil and filter, just as long as it is kept clean and installed correctly![]()
I only buy Extra Virgin Olive oil from Greece.I stop using olive oil from Italy when they got caught 6yrs ago adding sunflower oil and canola to the olive oil. I only buy Portugeses and California olive oil now. My Ducati couldn't tell the difference but my penne noodles could. YMMV
With a schmeer or red loctite? Those vtwins vibrate!The following is straight out of the Suzuki 650 owner manual:
Oil filter tightening torque:
20 N·m (2.0 kgf-m, 14.5 lbf-ft)
Correct. The owner just needs to let the smoke out of the electrics now and then.
It’s coconut oil now. Very healthy and also a mild laxative. Your bike will appreciate the reduced weight load.
Margarine or butter (unsalted type) is easiest to apply to chains. If you have an enclosed chain drive, you can melt it then pour into the chain case.And it makes the best chain lube too !
Gorilla tape works too. I put that sh!t on everything....if you are worried about a spin on enclosed oil filter come loose you don't need to stop it from turning at the thread, you can stop it from turning anywhere aka safety wiring. ...
So you've heard about filling the transmission with sawdust to quiet loose bearings....
In the tropics, you use bananas... except crushed up bananas actually is pretty good gear lube.
Works great!
You only need synthetic if your blinkers are LEDs on metric bikes. Metric bike alternators have a sinus wave pulse so their LEDs blinkers use mechanical flash synchros to smooth out the blinking. The synchros will corrode with conventional blinker fluid.I'm torn between synthetic blinker fluid, or good old fashioned dino blinker fluid. Someone told me that the synthetic might make by blinkers blink too fast due to less electrical friction, so I'm leaning towards the dino.
Discuss.
