LoneRonin
Breaker bar to remove oil filter cover and the drain bolts??? Seriously?! What's next? Impact gun? OP most likely does not have proper tools to do this kind of job. Get proper set of sockets first if you want to change your oil again. OP, go get proper sockets, and while you are there (CT or wherever) get the kit for removing rounded-off bolts.
It's really hard to say how tight is tight without showing it. Try it with the torque wrench first (yes, they sell those at CT and other hardware stores too), then you will know how tight is tight. And yes, if you overtighten those bolts in the aluminum housing, you're pretty much screwed and will need to learn how to install helicoil inserts.
Usually a 17mm wrench is all you need. Hand tighten the bolt and move it a 1/4 turn and that should do it. No real need for a torque wrench.
As for the bolt -have you called Royal to see if they have one there?
and I'm sure you guys have never done an oil change on this model of bike...
I have, over a handful of times. Yes, you need a breaker bar if you have the bolt properly torqued to spec or trust me, you will waste a lot of time getting frustrated and swearing and smashing tools on the ground...
Yes, you need a torque wrench if you want to tighten it to spec and it also doubles as a breaker bar because it has a lot more leverage.
