racepro171
ummmm......... jb weld? heli coils? how about a good tech and a tig welder? Sandy or Z would probably charge like 40-50 and its like new.
My thoughts exactly. Helicoil might extend the crack as you work on it. Since you gotta take it off just take it for a tig weld & retap it, a more permanent sturdy solutionummmm......... jb weld? heli coils? how about a good tech and a tig welder? Sandy or Z would probably charge like 40-50 and its like new.
+1. A helicoil won't help unless you remove enough material to eliminate the crack. If a replacement pan is not available, one could attempt to go oversize on the drain plug and tap new threads in the pan to match the oversize plug.
Shopping around for your parts can pay dividends.
http://www.ronayers.com/OIL-PAN-OIL-PUMP--C213440.aspx
