Make sure your pisser works before you head out. It may need a new impeller.
Sounds like you got a pretty good deal on it@crankcall
Now if my experiment does not work out, a reseal job on this motor is about $495 including $88 for seal kit and ~$70 for water pump. (water pump I may not need)
He actually does not have the kit in stock as they are on back order till sept/oct but can make up the kits from individual parts. I am really hoping I do not need to go this reseal route as that would cost me half of what I paid for my entire boat/motor/trailer.
His what?Make sure your pisser works before you head out. It may need a new impeller.
Well you could call it a telltale if you want, but that is a much less descriptive term.His what?
Agree, that gear oil is not looking great for being brand new (although you could have had some leftover water from the contaminated goo you dumped out the first time). I would take some spare gear oil to the cottage and check it part way through the week and change if required. Keep the motor out of the water when you aren't using it.@mimico_polak
Here she is.
View attachment 44334 View attachment 44335
@GreyGhost , as per your request I managed to snap a pic of her peeing.
@Mad Mike
Bad news (I think) for your picture request.
That is the result of fresh gearbox oil (Johnson/Evinrude brand) and engine running in large garage pail for about 1 hr 20min.
This picture was taken about 3 hours after the engine stopped running.
To me it looks like milky oil which is not what I want.
I will be visiting Klaus Marine on Tuesday and I am hoping the gentleman there can tell me that all is good, or at least good enough to run use the motor for a week.
I am hoping I can delay the reseal till the off season. I don't really want to spend $500 on a reseal job right now and I don't know if I would have the time to do it myself right now or be able to get my hands on a seal kit.
Any other advise would be greatly appreciated.
If the impeller is old and dry it may crumble and bits could end up anywhere in the system. Had it happen with an IO.You might be worrying to much, how did you determine it needs a new prop seal? If the motor has been sitting for a while, the seals might be dry. The lower unit will be marine hypoid oil, probably SAE 90.
before tearing it apart, I’d clean up outside, then fill it with oil, run the motor with muffs or in a barrel for 5 minutes. Wipe it down, leave it for a day to see if it leaks. A drop or two over a day won’t hurt. If it pours out you have a problem.
The impeller is another story, change that unless you are sure it’s been changed recently. An old impeller that has nor run will reform it shape and lose its elastic memory. It may will run fine for a few minutes or hours then crumble to pieces. For 30 bucks, change it.
Sale fell through (buyer bought another boat before coming to look at ours) so I took it out for a cruise. At the farthest point in the lake it died. Got a tow back from some friendly cottagers and brought it back to figure out where spark went. Ugh. Charge coil came loose under the flywheel and started to bang around. That took out the flywheel magnets, stator, sensor, plate and a few smaller parts. Amazing. Great reliability during our ownership and the farewell cruise chews up a crap ton of money (flywheel is 700 US, plate and stator are unavailable, sensor and charge coil are about 40 US each). Oh well, pulled the ad and on the search for parts. On the upside, the impeller is working great.I might sell my boat. 14' aluminum, flat floor, newish carpet, livewell with 30 hp tiller and two props (4 blade for pulling people and stock 3 blade) on a tilt trailer. According to my brother, I should ask 7. I wasn't planning on selling but for that much, someone else can have it. 99% of the time we use the FIL's boat anyway.
Yeah. My conscience would have been clear as it was running perfectly but I would have felt bad for the guy that bought it. My brother and dad care about boats and have contacts. They are getting people to rummage through their stockpiles. I put 50 hours on since I added the hour meter and if the boat market is similar next spring, it will sell for a little more than I have into it.You should be able to find a parts motor sitting about, or call a few 'service guys' , they seem to stock pile older motors.
Never take a boat (car, snowmobile,bike) out for a swan song once you have decided to sell it. Karma is a spiteful person.
OTOH , lucky for the f'er that didnt buy the boat, I'm usually pretty disappointed when an engine packs it in on my first ride. LOL
At least you got towed...so what happens if you're stuck in the middle of nowhere...who (and how) do you call for help?Nothing says fun like getting towed 7.5 km with kids in the boat and a dead engine![]()
You're facked. Seriously. Paddling a power boat more than a few hundred meters is an exercise in futility. If you are going places where help is not available, make sure you have some redundancy (2nd motor or boat of some sort). Some marinas will come and rescue you but it will take a while and be expensive (they trailer a boat to your lake, launch it, tow you and then reverse the process). Realistically, given the wind if a tow was not available, head to shore (hopefully near a road), get a car ride and come back for the boat with reinforcements (parts or trailer or boat or . . .)At least you got towed...so what happens if you're stuck in the middle of nowhere...who (and how) do you call for help?
