Is using a key that big of a deal?
Well done. Blind rage prevented me from asking that question earlier.
Keyless ignition systems are convenient and cool. You authentication system is single factor ("something you are") and single factor authentication systems are easily defeated. Furthermore, you seem to have used the identification component (cardiac rhythm) as the authentication factor. What mechanism are you using to identify the rider prior to providing the authentication? If you are going to forego the identification of the rider, you should consider a two factor authentication system where the rider must provide a second factor to authorise use of the motorcycle. This could be the key ("something you have") or a code entered through a key pad or similar ("something you know").cardiac rhythm which is unique and it authenticates the ignition on the motorbike through NFC (near field communication)
Without the key to hand, how does the rider open the gas cap to fill the tank with gas if they have a keyless ignition system? It's too easy to forget the gas cap key and get stranded with no way to fill the tank (or open luggage, or lift the seat). If you have to carry a key around for these additional chores, what convenience has the keyless ignition bought you (and at what expense)?
Unbelievable “Find My iPhone” Stories: The Good, the Bad and the Ugly
