Engine Replacement Help..?
if you look at his previous threads from last year, he was advised to sell the bike for a ninja 250
:lmao:
I guess he couldn't resist with all the endorsement from sexually confused K-pop celebs like BigBang, SuperJunior and DBSK.
have you actually done this?
I did it on my 04 zx10. I swapped the frame so I had everything removed from the frame with the engine supported, worked perfectly. It was actually easier than lifting the motor into my Gsxr but doing a motor replacement you have a rolling chassis to deal with so lifting the frame over the engine with the forks, wheels, swingarm all attached would be a pain.
exactly my point. If you are doing a whole frame swap..it is easier to put the frame on the motor, or "lower frame on to motor".
If if you are doing what this OP is doing, just a motor swap. It does not make sense to "Lower frame on to motor", you'd need to remove the front / rear wheels, and angle the chassie if you don't want to remove the forks. Wrestling a chassis that's 200-300lbs doesn't work for me. It is much easier to lift the motor into the frame.
The hyo has a tubular frame, the side should come off. With the tank removed, it should slide in (easier said than done.)
