I'm not a big fan of sharkbites.. They can always crap out on you. A lot easier to just sweat it with mapp. Using the blue stuff on wet lines is a real hassle, even though a bit of bread goes a long way
the best way to check an element is with a clamp on ammeter... turn on the upper element,, clamp on red wire,, then the black wire,, compare the 2 readings, they should be the same. clamp on the cold water pipe. you should get zero current flow in the water pipe.
a bad element can short to ground, and bypass the temp switch,, it will be hot to neutral connection,, well,, hot to ground. so you will see current in the water pipe ground,, when this happens,, the tank usually overheats too. and the pressure relief will be wet or show signs of leaking.
If they are immersion elements,, drain the tank, have a wet vac handy, and pull out the bottom element, catch the water and lime with the wet vac .. if the element is buggered , it will probably take a bit of yanking to get it out,,, once out,, clean out the loose lime,, then install your new element..
good luck... a lot easier to install a new tank.. especially with ferule style compression fittings.. no soldering needed.
Doesnt matter....They both carry the load.
Does the breaker trip as soon as you reset it or does it trip once in a while?
instant trip tells you its a short, while taking a while to trip shows a bad element thats pulling too much current. (on its way out...)
It will rust through and leak shortly. Just get another unit and plug and play.
i noticed looking at ct, hh and hd they didn't list elements in their catalogs, and talking to a pro it was suggested that replacing the element would just cause a leak so now the trick is deciding what water heater to replace with, i notice that my water heater has a pipe at the bottom and at the top and it's about 20-30 dollars more for that style over the ones with two pipes at the top... what's the difference?
also it's just me and some times my gf in a 4 bedroom house. is it worth while having a 60 gallon tank (what i have currently) or should i look at something smaller? hot water usage tends to be the dishwasher (3-4 times a week) and daily showers. I think my hot water heater is about at least 1/2 my electricity usage (don't get me started on the delivery costs).
Do you see any change in consumption in the next 5 to 10 years. Additional bodies etc,
Hell no, no threesomes so unless some one's imaginary friend steps in (and then I'm having the church charged with rape) or you provide the baby (I get the option to return it when it annoys/inconveniences/i get bored of it) no baby showers.Pardon the pun but I'll throw the baby shower :laughing2:
We have a gas flash heater and would recommend the same. Little box on the wall never runs out of hot water and doesn't cost a penny when hot water isn't bring used.
