Cheapo ($50) Stereo bluetooh headset and intercom review (deal extreme)
that sucks man.
still no issues from mine. knock on wood. different mics don't work even after resoldering?
I think its hit/miss with these things man. I bought it knowing quality control wasn't exactly priority for these guys. It's made by Netphone inc. in China.
Nope, I even tried the mic/headset from the second set (which works on the second set), and still no joy.
There is no way to fully reset the device either. The reset button doesn't actually reset, it just cuts the connection out. At this point one my units is not waterproof at all, because I sliced it open. I guess i could super glue it or something (or keep it in my jacket pocket).
I'll try a few other things and update on here. The second unit is still working, but it hasn't been used much at all.
^ Sorry for your trouble, but thanks for sharing it. It's helpfull to be able to see the innards. You said you cut yours open - does that mean the rubber was vulcanized together or there was some glue involved. Mine look like they were molded together, but if they were glued I'd like to pry them open gently and reseal later. Something like Shoe Goo or similar glue would do the job fine, but I'd stay away from superglue - it won't seal it well and it would be a ***** to remove.
Thanks V.
Yes, I cut mine along the top with an exacto. I actually tried to pry mine open, but it's impossible. From what I can see, it's set up like this:
3 pieces
[1] Antenna rubber holder
[2] body rubber with buttons
[3] bottom seal with cutouts for head phone & USB
I think the board + battery was shoved in from the bottom (headphone/usb end).
Then, the antenna rubber was put in place (otherwise, there would be no other way to get the antenna wire in the rubber holder.
Finally, the bottom (usb/headphone) rubber flap was put in and sealed with glue.
I couldn't pry mine open. The rubber would have ripped before coming loose. There is also 2 battery wires (very thin) right by the 3.5mm headphone jack - so if you do want to pry, be careful not to pull/tip the battery wire.
Yea...i'm not sure what i'll do with it. It's actually touch to squeeze everything back in. I also tried pairing it with another phone, and the mic still doesn't work. My only guess now is that the unit's mic output is dead.
Okay, seems all the the problems this device has comes from the little 3.5mm jack mounted on the board with 4 joints soldered.
I soldered 4 wires to the board, then soldered the other ends to the 3.5mm jack.
The MIC now works, but my gf said it's super fuzzy (probably needs to be soldered right on the board to reduce static. The soldering job on te 3.5mm jack is crap. I think if it was soldered well, and maybe hot glued to stay put, this would have been a super product.
Anyway. I'll try resoldering the 3.5mm. Jack back on the board. If it still doesn't work, I'll use it as a wireless Bluetooth headset with my good earbuds.
Thanks again. It looks like the only part that's glued is the flap cover and the hard plastic attachment protrusion (for lack of a better word). Speaking of the sad "protrusion" it fell off of one of my units so I had to glue it back on. Just something to have in mind if you take your unit off frequently. On the plus side, there is no opening behind that part, so the unit remains as waterproof as before. I'm thinking of just doing away with the whole attachment contraption and use good size and good strength velcro instead. It will be way more elegant and stable without any screws and brackets.
Complain to the seller, you have nothing to loose. I got 50% refund and I'm OK with it. Then you won't feel so bad for using it as a glorified bluetooth headset.
Yes, you're right. I'm not sure how the sealed this damn thing!! What did they do? mold over the chip board?
Well...good news: My unit is now working, and sound quality is better than before.
• I cleaned off all the old solder, resoldered nicely.
• Test to ensure it was working - it was, and the static noise was just like before.
• Strategically place electrical tape around some of the chips on the main board, which seemed to reduce static when covered.
• Wrapped electrical tape around USB and 3.5mm jack to ensure it stays in place, and held a lighter to it (1 second) to "seal it"
• Wrapped the remainder in electrical tape for added security and water proofing (again, lighter for 1-2 seconds to really stick it on).
I just called my gf with it, and he says it sounds like I'm on a regular phone, and I didn't hear ANY static on my end - at all! Not sure how long this will last, but it's pretty freaking good right now.
I just need it for my trip 4000km trip in August. If either unit works after the trip - bonus.
How do I voice dialing on my iPhone4? I hit some random button while riding (was trying to reduce the volume on my music), and it activated the voice dial. I can't replicate it. i would love to be able to use voice dial.
Don't have one of these units myself (not yet anyway), but someone above mentioned being able to press a button to play/pause your music. Try holding that same button down for 3 seconds.
I've tried that too...just keeps stopping/playing music. It's not really a big deal, but would be sweet if I could get it working somehow.
Well both of mine are screwed. I'll let them sit for a few more days and if it doesn't get better I'm opening this thing up. After riding in the rain the music just cut out and the LED turned RED. Now one of the unit has the red LED permanently on and the other unit doesn't have any LED on even after pressing the power button for 20 min. I tried the Reset button and nothing.
I let them sit for almost 2 weeks and now at least one of them is working again. I'm charging the second one to see if I can save that one too.
False alarm. The RED LED just turned on and won't shut off on one unit and the other unit doesn't want to turn on.
Oh well...
so I contacted Deal Extreme and explained what happened and this is what they replied... (spelling and grammar mistakes intact)
Sorry for the item being defective.
Then would you mind returning it back for a new one ?
We can riemburse you 35% of defective item value return shipping cost at most.
Anyone have a Chiglish to English translator? I think they are trying to say that if I send back my unit they will send me a new one and reimburse 35% of my shipping cost. It's too bad the post office is on strike right now.
As far as Customer Service, so far it's better then I expected. I didn't expect any answer.
That's how I understood it too, but it won't hurt to clarify with them.
I've had a pretty decent experience with DealExtreme customer support the few times I dealt with them. All my problems were addressed promptly and to my satisfaction, including a case where they just sent me a new item without me returning the old one (it was a ~$10 iPod external power supply with a faulty connector that was ultimately fixed with little filing).
Dood...just send it back and order from goodeals18. They ship in 3 days and take returns on defective/crappy products. They are based out of brooklyn - at least that's what it said on my shipping box. Only downside is that it cost $3-5 more than dealextreme, which is worth it imo.
DOOD,
The closes I've seen is this
https://ssl.zoovy.com/c=QEOoHi99XL1...tooth-Multi-Interphone-headsets-2010-ver.html
which is $132 + shipping.... Compared to $91.99 (free shipping)... that's a bit more then the $3-$5 you claim.
My friend,
You need to search harder. I don't claim, I know.
Here you go. The exact same thing I bought. Shipped in 3 days.
http://www.gooddeals18.com/product/SHKMBT88I/new-Motorcycle-Bluetooth-Multi-Interphone-headsets.html
I would search but that site is near impossible to search..
Also, you never answered my "+shipping" question.
Also, it's not the same product. Look at the picture. If you read this whole thread you will see that there's multiple version. The one you pointed out is not the same as the one from DealExtreme
http://static.zoovy.com/img/gooddeals18/W360-H360-Bffffff/8/8860i.jpg
http://www1.dealextreme.com/productimages/sku_35612_10.jpg
Ya the site sucks, but I use google to search the site.
Mine came to $98 shipped cdn dollars. So shipping was around $5 or so.
The product I purchased and linked is the same thing Fyrebug purchased. Look at the photos in his post (1st post) and compare to the one from gooddeals18.
No it's not.... Look at your helmet clips and look at his. Different version/product.
Mine were the exact same as the one in fyrebugs pic. U can take a photo of it if u like.
I repeat. My clips, wires, units all are the same as the one in fyrebugs pic.
Well mines broken. Used it maybe 5 times. While riding on Sunday it beeped like the battery was low so I got homePut it on charge for like 5 hours and now it won't turn on. Anybody have a fix before i try and send it back
