boyoboy
Just wanted to come back and report that I believe I've eliminated the rotor drag. I went back on Thurs evening and give the whole wheel install another go. This time I pumped the pistons almost entirely out so I was able to clean them entirely. I also picked up and added some brake lube to the pistons, which did the exact opposite of what it was supposed to and gummed them up real good. Cleaned them up again, and despite a brief stint of low braking pressure, they've been good since.
In the process I was able to determine that my forks are most likely out of alignment. Again, the only way I was able to get the front wheel centered was by tightening the axle nut way over spec to be enough to pull the right fork inward toward the wheel. The bike drives straight, but feels a little floaty at the odd time, and right turns feel a little bit off. I also doubt that the extra pressure on the fork is doing it any favours, and I really don't want to be riding when it decides it's had enough. Hoping it's a matter of them being twisted as opposed to being bent, which I've read can be a simple enough process to fix, but I can really only try one method (front tire between someone's knees, loosen fork bolts, and jolt things around). Most others require a triple tree stand, which I don't have.
Other than that, I realized one of my clip ons is bent upwards. Tried straightening that using a vice, but that wasn't able to do much so I'll need to replace that. Other than that, everything else seems ok.
slightly bent fork tubes can be straightened....hope the triples are ok.
