Pic 1. So try continuity test on the two terminal if the connection is solid if the wires get wiggled.
Pic 2. Is there nothing under the rubber on the left? U can also check the wiring diagram if any 2 wires is a complete circuit. And test thanway
I see. Does pic one lead to the wire harness of pic2?
Use whatever conductive material you can use for diagnosing. However, don't break the contacts. lol. If pic one doens't lead to pic 2. then there must be a way out unless it's connected to a relay.
