Im new to this fourm and in need of some advice. I'm having difficulty swping out my water pump on a 99 R6. I can't seem to get the hoses off the old pump.
Loosen the clamp entirely and apply brute force. Seriously, they bake on. You can try very gently lifting up the hose around the water pump inlet/outlet with a small screwdriver or just simply work on twisting the hose back and forth until you break the bond between the hose and the alu housing. Try not to damage/tear the hose or you'll have to get a new one.
Thanks for responding to my post. Using brute force and screwdriver worked like a charm, making short work out of those hoses. Had the old pump out, and the new one in within a half hour.
