Hey guys, I got water into my gas tank because of rain yesterday. The gas cap wasnt closed properly so im assuming thats what happened.
It started up and rode fine for about a KM. Then it wouldnt really respond if I twist the throttle. First gear was okay, but onwards it would jerk as I twist the throttle. However the bike stays running.
I drained the gas tank as much as i could (So not all the way). Filled it up again but same thinghappening.
I didnt really ride it after I filled it because its such a pain trying to when it doesnt respond. Could that be the OLD gas in the pipes or float that is still causing the problem?
So whats the fastest way getting this running again? Should draining the float (i think thats what it is, the screws under the carbs) help?
thanks!!
thanks!!
