Interesting post from a guy here at GTA:
I never thought that millimeters would make that much of a difference in fuel consumption!
it is simply the difference in diameter of a new tire vs one that is worn out. And this difference can be compounded if you happened to have bought a new tire that differs from the profile/diameter of the OEM rubber, which is what the odometer is calibrated to. In many bikes, this can equate to as much as 2 - 5 mpg. If you happen to be skeptical on this, this can be proven by using a GPS both before and after swapping out the old for the new tire.
As someone who once bought new rubber every 2 - 3000 km (sportbike compounds on RR's) I have replaced a PILE of tires in my years and always have tracked mileage for various reasons...some of which lets me know if a thermostat or sensor had gone or going bad. Took me a while to put 2 and 2 together but finally made the assimilation. Felt a bit thick when it did finally dawn on me, because of course, a new tire turns fewer revolutions in the same mile than a worn out one does.
