turn singal relay led conversion
Ksharp
working on a project cb750f, im sure its on a 12v flasher, im swapping out the bulbs for led lights. im sure i need to add a resistor some where to make them flash or do i just replace the relay, any tips tricks and hints ????
thanks
It's better replace the flasher relay. The resistors get hot, take space, and essentially are there to waste power.
Edit:
Or you can just leave the current flasher there and live with the faster blinking.
recheck your postive and negitive connections to the harness, make sure the black with the yellow tracer is ground.
