Testing eletrical with car battery | GTAMotorcycle.com
wild2crazy
Looking on testing my charging system (stator and regulator/rectifier).
Would using a car battery in anyway give me false reading from a digital multimeter?
Car battery will not be hooked to the car just to the motorcycle battery
Old Battery was 6 years old figured got a little dimming lights at low idle so i grabbed a new batttery toss it in bike starts fine runs fine no dimming light.
I come back to the bike after month decide to turn her over to cycle gas and no power so inspection of battery reveals sulfation which equals death
I know. charging the new/dead battery only brings it 49% which when left unhooked slowly looses charge by just sitting there.
Any other thoughts possible charging malfunctions i should have a look at ? I am going to pull the readings from the multimeter tomorrow.
No problem at all.
So long as the batteries are of the same nominal Voltage (12 Volts), there is no problem to run the batteries in parallel.
If you can; check the stator Voltage and current while the engine is running. All 3 legs should be equal, Voltage could be anything up to 15 Volts, current should be ~ 20 Amps (on 2006 GSXR)
No problem at all.
Voltage should be 60V per phase, 55V-6oV will do ....
thanks for the info boys i got the service manual for replace requirements
hopefully i can find the culprit :)
