Suzuki GSX-R 750 K4 frame+engine
BakosRT
I have a frame with clean title, engine is still in. Has the wiring harness, injectors, throttle bodies, etc. For more info bakos_rt@aol.com Asking 1100 obo
Also have other parts, radiator, headlight, fuel tank, M4 exhaust, Galfer rotors...
750 for the engine and frame, subframe, fuel injectors, wiring harness, tb... Rad with fan and reservoir 100, *headlight 60, fuel tank with pump and gas cap 110, M4 titanium bolt-on pipe 100, Galfer front rotors, 280, Michelin tire(f-120, r-180) still has good tread left 80, passenger seat 70, front-rear pegs with brakets 50, air box with oem filter 30, led clear tail light 30, rear rotor 20, oem shock 50, rear master cylinder 25, windscreen 20, stva 100, ecu 50
