Suspension pre-load. Do I have a problem?
cupojoe
New member
I have a 06 Honda VFR.
The rear preload adjustment has no tension to it if i back it off to the low rating. Is this normal? I don't recall this being the case in previous years. Also I feel like the bike does not sit as high when I do dial it up.
Thanks.
worn out
rebuild or replace
If the shock has a hydraulic preload it may just need to be topped up with fluid and bled... depending on the design you may or may not be able to do this yourself. I would then compare actual preload adjustment travel to theoretical. I have an Ohlins shock that only gave 1-2mm of adjustment when I first bought it (used). After doing some research and bleeding the shock while still on the bike I was able to restore the adjustment range back to 8-9mm... however, with the adjustment knob turned all the way out there is still a small range where no "pressure" is felt, I imagine because the piston is pushing on the small amount of air left in the system.
If you check the VFRforums...I think other 6th gen owners have installed 929 shocks in their bikes.
