Green Machine
Ok just bought an older bike which was running about 95% as to be expected being 25 years old. then yesterday it wold only start with the throttle fully opened, and would not rev at all, only idle. I thought **** obviously something wrong with the fuel somewhere, or the damn carbs. So , I did some research and found that most people were using seafoam to clean out their system. I went to CT today to pick some up and read the directions- it's a project to use that stuff. so after reading a few products I went with this STP stuff. had the same claims, with less work. I added way less than recommend , ran it for about 4 mins and Blammo!! that thing was purring like beast in heat, it obviously blasted out whatever was blocking the fuel. If I were to guess it hasn't run that well in years. I gave it a little run, the responsiveness increased 100% and just felt clean. I also shut it down and restarted it a few times with no issues. I'm not going to recommend this 100% as of yet until I try to start it again tomorrow, who knows it may totally screw it up over night or fingers crossed will be back to new still. I will update tomorrow. in the meantime here is the stuff or the link to it : http://www.canadiantire.ca/AST/brow...+Fuel+System+Cleaner.jsp?locale=en#product_aa I think if this works it might be a better fix than pulling your carbs off every time there is a problem. wish me luck!
