-D-
Banned
Ok, so I am trying to setup a 2 layer system.
I know someone here has the answer. This thing is driving me bonkers and making my head hurt![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
I have Tomato (Shibby, newest version)
Goal- to connect a virtual wifi connection by using the router in wireless client mode.
Setup- I the router set as a wireless client (not bridge, don't want bridge). This will give the user the ability to see that they are on their network and will have a different ip range. The main IP e.g. 192.168.1.1 BUT I want them to be on 192.168.10.1 with DHCP turned on and I want them to see a different SSID/AP name to connect to e.g. Guest
I did do some reading but I got lost. They got into setting up virtual lans along with the virtual wifi.
I have the router setup as a wireless client and it's working. The problem is you can't tell if you are connected to the actual access point or the "repeater/wifi client".
If you can post some links with screen shots, that would be great.
If you can type it up in the steps to setup I can work with that too.
Thanks
Thanks
