Jam,i call it. Awesome stuff.I’ve had good luck with Loctite 518
I was reading the label on some Permatex (didn't buy it) and noted that after applying the sealant you are to finger tight the bolts and then let it sit an hour before torquing the bolts. Is this standard?
I would be afraid of getting a thick area that would then not squish down fully.
This is actually between cases with no gasket, but I'm sure that still applies.It stays squishy for a long time. It is a rubber-like adhesive, will never completely harden. Do not overdo it. Just paint on enough to do the job. It soaks into the gasket, then when you torque it down the gasket squishes and seals tightly.
Use the 518 Loctite the Permatex form a gasket stuff is junk
Amazon.So after an indy auto parts, NAPA Ideal Supply and crappy tire I came up empty handed. The NAPA guy spent like 15 minutes on his terminal and couldn't find Loctite 518. He found what he thought was similar but it was the caulking gun sized tubes.
Any suggestions for a supplier?
Brafasco or Bolts Plus carry 518. But usually only in the $90 caulking gun size.Thanks Wingboy.
The luddite in me was hoping for bricks and mortar.
