So I picked myself up an Aprilia RS125 which was kind of in need of service (chain and cables had never been tightened for one).
When I first rode it the choke, clutch and throttle cables were way loose. Tightened them up and the chain and now it rides much nicer. However, after I did the throttle cable, I noticed the bike would idle high (~3-4k RPM) when I stopped at lights for a few seconds before dropping back down to normal (~1.5k).
After I did the choke cable, the bike starts up much nicer when cold (I presume because the choke is actually doing something instead of just tugging on a loose cable) but now the high idle condition happens all the time and it doesn't drop back down. If I release the clutch slowly and let the bike pull the revs down until near ~2k or so and then pull the clutch in again, it will stay down around 1.5k. Also, when it's cold enough that it's not properly warmed up but warm enough that I don't need the choke or to blip the engine to keep it running, it idles at 1.5k fine.
I know the carb could probably use a good breakdown and cleaning but is there anything in particular I should be checking? I can't seem to find a "how to" for removing the cleaning the carb, either. I can find how-tos for just cleaning but nothing that explains how to go about removing the thing. I'm generally alright at doing these things with some decent instructions but I'd rather not go in blind. I've only done things like brake jobs, fairing swaps, swapping out an alternator, replacing generator cover, etc on my own in the past.
Thanks.
Thanks.
