Rear seat replacement - stupid question but ive searched and need help | GTAMotorcycle.com
xxxbrandonxxx
New member
I bought a bike that had a track one piece rear seat on it, I want to convert to have a passenger seat, is it as simple as buying the rear fairing and seat and pegs obviously? or is there some kind of frame support needed
Have patience with me and thank you
Are you planning on putting it in the road?
If so as long as it has the stock Sub-frame and has all the goodies left back there (Lock, wiring....) it shouldn't be a problem.
Best bet is to take off the rear fairing and see what you have back there.
I use it on the road now, it has all wiring for sure.. The sub frame I wouldnt know...I know the fairing has two screws underneath the seat, two on the top of the fairing close to the original seat, and then a couple underneath by the blinkers
On that bike you can hack off the rear subframe where the passenger seat goes to save some weight.
If your around my area we can have a peek to see what you might need.
