Top Gun Ryder
Re: What Oil are you using right now and why?
Hey guys I really need some help here please.
My bike 2006 gsxr 1000 29,000 miles
bike has a M4 full exhaust no other mods
it came with a Bazzaz ZFI and a X-Tre but I've taking all that off to eliminate any problems and it's still doing the same.
But as of now it's back to stock with a full M4 Exaust.
Ok now here is my problem.
My bike starts up and idles fine when I rev it in neutral it revs to 8k-10k ish and sounds like it hits the rev limiter shoots flames and had sputter popping characteristics. Ok but when I ride it it stall at 8k ish like a rev limiter it sputters and back fires like in neutral and want go any faster no matter what gear I'm in.
Ok now my secondary injectors :
i noticed my secondary injectors never spray. I swapped the primary injector plugs to the secondaries and they work just wanted to be sure they sprayed. But they never spray when plugged up correctly I watched with the air box open even going they the gears on the bike stand they don't spray. The positive wire to the injectors work but the ground wire doesn't come alive at All on the secondary injectors.
Ok ok things I've done :
New ECU
i changed spark plugs
had one spark plug dead before I changed them
but it still revved the same just idled rough.
checked coils one coil seemed weird but had an ok spark. This is the coil that the spark plug was dead on.
eliminated the kickstand switch
check clutch safety switch
cam timing is good
changed fuel pump with a used one out of my friends 08 Hayabusa's
New ECU
cam timing is good
