atss2006
Hey guys,
Bought a 929RR for the track. was told the stator was shot when I bought it. got home and hooked up to a boost and fired it up ( I leave the booster hooked up because I don't know about the stator so I don't want it to die because of power). Running fine for about 30sec - 1 min. Then it quickly starts to reverse surge (rpm drops then returns), then she quits. Lots of power, if I key off key on, I can hear the fuel pump prime. Bike cranks hard, won't start again, just cranks and tries to catch. Leave it (I tried the next day) and she fires up fine...then goes thru the same process. fuses are good, checked the relays they're good. No FI light, no error codes. I'm kind confused because it does run for that little bit but won't restart after it dies. I'm thinking something is getting overloaded and shutting it down but not sure where to check.
Next up I'm going to test fuel flow, just to make sure the pump or flow isnt flaky.
