Parting out Parts GSXR 600 750 2006 to 09 | GTAMotorcycle.com
Parting out a 06-07 GSXR 750, and 08-09 GSXR 600 same as 06/09 GSXR 600/750
All parts are OEM and in good condition. If damaged, I will state it.
If you need photos, email me at Aboogie973@gmail.com
Rectifier $100, no damage
Fuel pump $100, no damage
Subframe complete with battery under tray $200, no damage
06/07 750 Frame with clean and clear title, no damage $1750 firm., no damage
OEM left mirrors $30, no damage
Ram airs left and right with windscreens $75, no damage
09 Radiator with fan and coolant bottle $250, no damage
Swingarm with stock chain $30, no damage
Wiring harness $80, no damage
Smoked windshield $30, no damage
ECU $150, no damage
Injectors $120, no damage
Airbox $30, no damage
06-07 750 Motor $800, no damage
Complete lockset with OEM Key $150, no damage
Lower triple tree $100, no damage
Kickstand with sensor $20, no damage
06/07 Stock headers $60, no damage
09 Front rim with rotors $350
06/07 Rear rim with rotor sprocket and hub $200, no damage
Front driver seat $30, no damage
Rear passenger seat $100, no damage
K&N Air filter $40, no damage
Chrome keyless gas cap $30, no damage
06-07 Complete front end , from top to bottom with handlebars, switches, calipers, triple tree set, front master cylinder and res, without front fender and rim $650., no damage
Blue front upper fairing, one tab mount is cracked, but holds fine $30
Blue and white Left fairing, with ram air cover has a whole cut out for the frame slider, $130
09 GSXR 600 motor complete with wiring harness, Airbox and ecu $1300, no damage
08-09 600 Complete front end , from top to bottom with handlebars, switches and mode, calipers, triple tree set, front master cylinder and res, without front fender and rim $650., no damage
06-07 Headlight $200 with low beam bulb
06-07 Upper stay $100
Left complete shifter rearset $75
Right complete brake rearset with caliper $75
Rear caliper $20
Sold parts as of right now.
06-07 GSXR 750
Front rim w/o rotors
Tail lights
Rear shock
Frame sale Pending.
Fairings w/tank sale is pending.
