I had a wonderful high-side over a month ago where I scraped the left side of my tank. I've been taking it to body shops and all are mentioning they'll need to sand down and repaint the entire thing, (reapplying the factory stickers) which will run between $300-400 (plus $150 for stickers), and involving completely removing the gas tank for them. I'm looking for a quicker more cost effective alternative as the bike is a 2004 with 70,000km.
Here's some pictures from different distances. The scrapes are just below the silver graphic which I'd like to keep in tact. I'm wondering if I'm better off doing it myself by sanding it down a bit more to remove all the rust in the grooves (and try to smooth out the ridge where the metal meets the paint), putting primer, and trying as best I can to spray it gloss black... or do I just suck it up and take it to someone else who can do a better job then me.
I'm fine with their being a flat spot due to the wear down, but what I'd like to achieve is a somewhat smooth gradual finish to it, where the paint blends as much as possible and doesn't look like a complete hack job.
Also, I'm looking at purchasing new replacement OEM fairings (as I can't find any used) for the side and tail. I've been looking into buying the cheap alternatives from China, but I've heard nothing but nightmare stories with screws not aligning, and melting plastics.
Any recommendations? Thanks.
