Easier on moving parts during cold weather start ups. 0W a tad better.
Awesomeness........another oil thread.
... but that's not how it works. It has to be designed to use that thin oil, and will need a small diameter big end bearing and small clearance, which OP don't got.
Start here to understand oil viscosity:
Not a big fan of BOB... I blame him for everybody using Rotella oil and that's just wrong. Somehow people out there in internet land got convinced Rotella is GOOD oil, and I blame him. I'm probably wrong, but I'll hate him for it anyway.
Gives me somethin' to do. I'm bored. old man yelling at cloud emoji here
...BUT ANYWAY... the only time you have to even consider going to thinner oil when it gets cold is if the starter can't turn over the motor fast enough to start the motor... and if that's your problem I'll BETCHA your problem isn't oil. It hasn't been THAT cold.
MOSTLY, if the motor starts, you're good to go. Motorcycles have a displacement oil pump and will pump frozen grease with sand in it, as long as it's turning. The oil in the system heats up from friction from getting rammed through the oil pump and all the small gaps we push it through, almost instantly. Your oil problem at startup is oil pressure because all the oil gaps are huge because all the metal has contracted because of the cold , NOT oil temperature or viscosity. You're not doing the motor any favours by starting it in the cold, but oil temperature isn't the issue.
If it gets cold enough that have to worry about oil: it's too cold to ride. The bike will go, you'll freeze your nards. If your properly tuned bike, with a fully charged battery, fresh fuel, with the "average user" oil in the crankcase doesn't start when it's cold, it's because the people that designed your motorcycle think it's too cold to ride and they think you're an idiot, and you should go inside where it's warm and get a nice hot cup of tea. You need to sit by the fire. What were you thinking? Have you looked out there?
It's a design "feature" (that's not included on euro bikes...their designers are looking down their nose at ya even when it's warm and sunny).
... unless, of course, you have a kick start bike. Then everything I just said goes out the window and you have to move to the top of a hill... and you'll need to find a job at the top of a hill....
