No water coming to backyard hose
cbcanada
Banned
I turned on the back yard hose for the first time since winter. The main switch from inside the wall is turned on as well. But there is hardly any water coming out.
Any ideas?
"If i was educated, I'd be a damn fool"
Go look in the basement to make sure that's not where the majority is coming out? Tried the hose with no end on it.... :dontknow:
Its the exterior hose. No water going through it
If i take it off i got water coming from faucet
Ummm...
This is a likely scenario. Start at one end of the hose and work your way down. If you notice any kind of kinkage, untwist and fluff. Continue and repeat as needed.
I got it sorted out. The plastic extention piece broke inside. I am guessing from the brutal winter
Glad you got that worked out. Turns out my advice sucked. Probably should have made a flow chart.
