[TABLE="class: tborder, width: 100%, align: center"]
[TR]
[TD="class: alt1, bgcolor: #EFEFEF"]Hi Guys,
I need your help. My bike kinda chokes in higher RPM when I accelerate; when RPM goes back to zero and after couple second comes back on when I let the throttle go. This happens in hard acceleration or anytime the bike reaches to higher RPM (7000+). The bike runs great in idle and revs up with no problem. I have to mention that the bike was dropped on its side (side stand gone to a damn hot asphalt!!!) and couple days after it was washed with high pressure water (blame it on me, my first time!!!). here are the things I have done so far to resolve the issue:
1- Changing the air filter in order to eliminate the possible issue of clogged filter
2- making sure the battery is secure and tight in its place and all the connections are good.
3- Looked for tip over sensor (someone said it is a possibility!) but could not find it!
4- Used Lucas fuel injector cleaner to clean up fuel lines and injector due to the possible dirt from pressure washing.
I have gone to forums and read similar posts and some have suggested to change the spark plugs. Please let me know what do think? thanks in advance.[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
