Set the cold pressures to Michelin's guide, then check them again after they've been on the warmers.
As I recall, you're looking for a 10-15% pressure rise (cold to hot) but check them again after you come off the track.
As suggested, the current Michelin distributor can provide you with more detailed information.
Ok so what if you get more/less rise between your hot/cold pressures? Deflate and start over?
Cold pressures are irellevent when using tires designed to work with warmers. Off the warmers and hot off the track temps are all that matter.
If you don't have any other information to go by, this will at least get you in the ball park (?)
You're talking temperatures, the original poster and I are talking pressures - apples and oranges....
I'm talking pressures. Hot off the warmer, hot off the track tire pressure.
Then what is your suggestion - should there be any rise ?
if your quick, rear 24 hot off track, front 34. they are a much thinner tire and thus loose heat quickly, so check right off track, dont get back to pit, remove helmet,gloves ect. do it asap.
Are you sure they're cold pressures? Cold pressures are useless with slicks.
Wayne at Kennedy Motorsports is the Michelin guy I believe.
thanks, heard back from Wayne, he confirmed that Michelin does not provide a hot pressure, only cold, he said 23/24 off the warmers is what he recommends
You people do realize hot pressures are different for everyone and each track? You must set your pressures at what you may assume they might be and then adjust as you come off the track. There is no "Magic" number. What works for one is not really the same for another. I work to get a 0 increase when on the track. That takes a bit of work. If you get increase you have problems. Hot pressure is directly related to how you ride. So welcome to the new tires, get some good warmers you can replicate your off track temps and also a good pyrometer. Otherwise,, maybe some dice. We had the top 5 at the RACE Superseries on our new stuff. All of the five were taking off track temps and pressures ALL weekend to get the tires to work right. That goes for Dunop,Michelin and Pirelli.
We had the top finishers in the Superbike class all on our stuff. Less Thomas Casas but he was on the old style with a hotter thermostat.John, what do you mean by the top 5 guys running our new stuff? Tires? Warmers? Pyrometers?
Are these the new warmers, I believe you were talking about in another thread, that are programable and go up to 120c?
What are guys using to measure the actual temperature of the tire? What seems to be the most accurate?
The programmable we carry and the one we are using goes to 100 C. I am discussing a 120 C model but not sure I can or will introduce that to the general population. "Most" can use the 100 C model just fine. Most guys use an infra red pyrometer. When we use the infra red we just check rim and side wall temp as well as the tread.And ,honestly, for most they are easiest. I use a probe style pyrometer,,but that is easy when you are not coming off the track with gloves and leathers and trying to hold a bike. So tread temp in a few spots to see what the averagae is, check the side wall, and check the rim to see what it is going up to. The rim will help tell you the heat soak you have. If you are getting a one-two lap wiggle,,,then you are not hot enough.Are these the new warmers, I believe you were talking about in another thread, that are programable and go up to 120c?
