Looking for a Fuel pump motor | GTAMotorcycle.com
revalot
Active member
I have taken the fuel pump apart on a 07 CBR 600RR and the motor needs to be replaced. I have tried to search with the model number on the botom but nothing has come up. Does anyone know where I can source one or what I should be searching for?
prolly have to buy the whole pump...
another option if you don't mind changing things a bit is buy an external 12 V fuel pump,
having the room for it might be an issue, and will only work if the old one will still pass fuel
The new pump will come with a new suction filter (the "sock" on the bottom) but there is probably a filter inside the fuel pump assembly to capture trash from a failed pump before it gets to the injectors. That filter is probably not replaceable. Try to backflush it the best you can. Clean out any trash from inside the fuel tank, too.
I actually purchased a whole new tank and pump for $100.
This was going to be a back up pump or a resell. I was told you could find the pumps for cheap on eBay, but have not found any.
