LED lights | GTAMotorcycle.com
LED lights
Do you want something to replace the stalks, or are you looking for something to clean up the back of the bike?
Heres the back of mine:
Thats with a Two Bros exhaust and the kit they include with it, but it gives you an idea of how the bike can look with the back end cleaned up a bit.
rmeedic, I have the same set up as you, i just had one of the bulbs go and saw on the fz6 forum that some of the guys were having bulb go out quite a bit and were switching to LED bulbs so i thought i would try it.
I had a bulb go too and I couldn't find a replacement, so I did switch it to LED signals... When you do LED lights, you need to make sure you do positive to positive and ground to ground or they won't work.
These ones won't do the job for this set up...
http://www.ebay.ca/itm/NEW-Black-LE...ccessories&hash=item3374d4cbc3#ht_2215wt_1270
These are pretty much the identical style to the ones I threw on there. They work good, have been on for about 2 years now and they still work just fine!
Do i need to get a resistor or will they work without? I have found some that say that a resistor is recommended.
Resistor isn't right if you have LED lights that draw much less power. Better to change the OEM flasher to a flasher that will work with LED lights.
I can record how fast mine flash.
I have LED flush mounts up front and LED in the rear and they don't pulse too fast. The next time I'm out with the bike I'll record it for ya and post it since I'll be able to give you the best idea what it looks and functions like.
An example would be like this. It's called 'hyper-flashing'.
http://www.youtube.com/watch?v=B1t_T5m-wQI
He's showing his signals but that's somewhat how the flash speed will be.
It's somewhat dangerous too because people will not notice it's blinking when it's too fast..
I got the rizomas and the flasher relay today, installed the flasher relay and need help with the wiring of the signals. It came with two load resistors and i was wondering if i need to use both, one or none. The instructions say to use two but that is without the flasher relay, any help would be appreciated!
I pretty sure the relay and the load resistors will do the exact same thing so use either one but there is no need for both.
