Just ordered a **** load of parts for the F4i
rob_96
So after taking a few turns and feeling the front end shift on me in a turn I figured something was wrong. I put the bike up on jack stands and checked for play in bearing, up and down nothing in the forks, Left and right yes there was play in the wheel bearing.
I know the bike has been down before from the previous owner so figured i change a few things.
So I called Honda and they wanted a lot of money for the parts. Then i found this online dealer in the states and got it all shipped to door for $173.16.
Just need to wait for them to come in and then spending some quality time with the bike.
Honda wanted $487.98 for all these parts
Order Number: 2671393
Order Status: Processing
Shipping Agency: USPS
Order Subtotal: $137.21
Order Tax: $0.00
Order Shipping Charges: $35.95
Order Total: $173.16
Payment Method: Credit Card
Order:
Qty. Part Number Price Per Item Special Order Product Name
1 44301-MBW-E11 $32.98 No HondaMC - AXLE, FR. WHEEL
1 90113-438-000 $5.25 No HondaMC - BOLT, L.
1 44311-MS2-000 $6.60 No HondaMC - COLR, FR. WHEEL SIDE
1 94050-10000 $0.85 No HondaMC - NUT, FLANGE (10MM)
1 94050-06000 $0.65 No HondaMC - NUT, FLANGE (6MM)
1 2-BCPR7ES $2.95 No NGK SPARK PLUGS
1 44311-MBW-E10 $6.37 No HondaMC - COLLAR, R. FR.
1 90305-ML7-000 $7.01 No HondaMC - BOLT, FR. AXLE
1 94101-10000 $0.47 No HondaMC - WASHER, PLAIN (10MM)
1 17210-MBW-D21 $36.43 No HondaMC - ELEMENT, AIR CLEANER
2 91252-MC4-013 $4.80 No HondaMC - OIL SEAL (28X47.2X7)
1 90162-MCJ-000 $1.79 No HondaMC - BOLT, FLANGE (10X55)
1 44620-MBW-E10 $9.32 No HondaMC - COLLAR, FR.
2 91052-MBW-E11 $8.47 No HondaMC - BEARING (20X45X12)
I will put an how to when i do all this with lots of pics
Cheers
Vito
Your purchase are questionable....
--> Was your axle bent?
--> Whats this part for?
--> Your spacer was bent?!!?
--> This is some sort of a pinch bolt? Was the head stripped?
- Fender bolt? only 1 PC?
--> What would you do with 1 Spark plug?
--> These are $10 from any parts store or hardware store...
--> Bearing seal....pricy!!
A good aftermarket bearing kits run's about $30.....with seals!
- The guy dropped the bike before me, and i was unsure if bent or not, i would rather change it
this for the rear sub-frame bolt fell out on me
--> Your spacer was bent?!!? - Same thing with shaft i would rather change everything, that goes with it.
--> This is some sort of a pinch bolt? Was the head stripped?, Nut for the rear subframe bolt
Washer for the rear sub Frame bolt
--> What would you do with 1 Spark plug? - Friend gave me 3 new ones... so i only needed one
Same at rest of axle part
--> This is some sort of a pinch bolt? Was the head stripped? - Stripped from previous owner
--> These are $10 from any parts store or hardware store... I figured that run Honda Parts due to me not sure if other stuff will be safe or work.
- Honda wanted 9.35.... so this is a lot cheaper
- $8.47+ $4.80 = $13.27 for Bearing and seal... that's cheap?
I figure that these parts are not the most expensive so id rather change things i am unsure about and be safe. This is my first motorcycle and not sure what the other guy did before me. She has 26k on her so why not change a few things.
cheers
rob
- $8.47+ $4.80 = $13.27 for barring and seal... that's cheap?
cheers
rob
What's the how to going to show? How to take out a bolt? and replace it? How to install a washer?
Jeez, don't rain all over his parade :P. The man wants to contribute, good on him.
Thanks man,
I have to change air filter, plugs, wheel bearing, front axle and few bolts. I feel like there was useful how to's there.
Cheers
Rob
Hi Rob: What's the name of the store where you bought the parts?
Jorge
So after taking a few turns and feeling the front end shift on me in a turn I figured something was wrong. I put the bike up on jack stands and checked for play in barring, up and down nothing in the forks, Left and right yes there was play in the wheel barring.
Order Tax: $0.00
Order:
Cheers
Vito
$10 for 1 washer at a parts store? Remind me never to go shopping with you.
