My 1987 FZ750 is having a very interesting ignition problem, now first off let me explain the formation of my engine to my ignition coils. lets assume my enings piston are in order from left to right 1,2,3,4 and igniton coil on the left we will call igiton coil A, which feeds spark to cylinders 1 and 4. where obviously igniton coil B (on the right side) feeds spark to cylinder 2 and 3 anyways at idel i can disconnect spark plug wires 1 and 4 (fed by ignition coil A) and the bike will idel the same but obviously when i dissconnect spark plug wire 3 or 4 the bike shut off. so basically the bike between idel and 4000-5000 rpm is runnin on cylinders 2 and 3 but after that rpm the bike runs perfect! what would cause the coil to give no spark at thoses low rpm and spark at high rpm (keep in mind the bike has a generator (DC current) which i think may have something to do with it) its to my understanding the either a coil works or it does not. ALSO i must include that when i unplug cylinders 1 and 4 at idel that all bar metal i.e. the frame gives me a shouck when touched.
thank you for reading all that
