arogal
When I purchased the '09 zx6r there was an HID kit installed (low beam only). In September I needed to replace both the stator and rectifier. The previous owner went through the OEM stator/rectifier, and when it was sold to me they had been replaced with Ebay China aftermarket (found this out months later). My mechanic advised me to never get cheap aftermarket charging system parts for the bike, so they were both replaced with OEM. He also said that HID kits can be hard on the charging system as it takes alot of power on the initial start up of the bike, but once they have charged they actually use less power than regular bulbs.
Little back story here....back in July my lights would cut out on me when I hit bumps for a about 2 weeks, then my bike felt like it wanted to stall every here and there....and eventually cut out on me when I pulled in my garage. Low and behold there was a loose battery connection on the positive terminal. I tightened everything up and she was good to go. I didn't think at the time that it would have been a good idea to charge the battery, as it most was likely dead from not getting a proper charge. Would the loose battery connection for 2 weeks or so put alot of strain on the charging system, and maybe that's why both the stator and rectifier needed to be replaced? I an see it possibly being a cause as the stator and rectifier were over working to keep the battery charged while it was losing connection....and with time they just crapped out.
Anyways, back to my main point, do HID kits really put that much strain on the charging system? If so am I better off getting an LED kit for the bike? It does have projectors, which put out awesome light at night with the HID kit. If the bike had the stock lights I would opt to an LED kit, but since there is already and HID kit in there I'm not sure if it worth the time and money or not.
Thanks!
(PS I should have posted this in the technical section)
Thanks!
