bboySushi
Hey guys, I know a lot of you are pretty savyy with lighting/electronics, so right now I want to build a portable (still outlet powered) light table/box for tracing. Probably somewhere in the size of 16 x 20".
I'm having difficulty figuring out what light source to use. The easiest (but not cheapest) would be to buy two desk lamps with the short flourescent looking lamps (or maybe they are just tubular halogens), pop the ballasts out and put one on each side of the light box. Each of those lamps would probably run me $30 each though. I might as well buy one of the $120 light boxes from Loomis in that case.
I would love to use LEDs as they don't run as hot and are much less bulky, but I'm not sure what to get to give a bright uniform light, and how to buy/hook up a power source. I thought of using LED tubes/christmas lights from home depot but I think the effect would be very patchy.
Is this something I'm looking for? http://www.led-outlets.com/index.php?main_page=product_info&cPath=227&products_id=245
I also need to pick them up this week so I can buy the materials to build the actual box (some sheet metal, plexiglas and wood).
