bboySushi
I have a Scorpio alarm hooked up to my bike. It runs in series from the bike to the signals, and another power line that just goes to the positive on the battery. Everything works fine. When I first got it I didn't ride much and eventually the alarm drained my battery and my bike was stuck at my girlfriend's house and I had to recharge. Since then I decided to install a switch running between the battery and the alarm. Now here's where things get interesting:
1) When the switch is off, the alarm goes off/emergency lights flash when I signal. Therefore I have to keep the switch 'ON' whenever I'm riding.
2) That wasn't a big deal, but when my fuse blows on the alarm (I think orig. was a 10A) the same thing happens. Obviously not good to find out when you're riding that you can't signal.
3) I bought another switch but it didn't change anything.
Everything works fine with the switch on, but eventually maybe a week or two of riding, the fuse will blow.
So, the big two questions are:
1) Why is the alarm fuse blowing? It did not seem to happen before I installed the switch which is curious. I will bypass the switch this week and see if it still blows.
2) How can I get around this and still install a switch? I assume it's some kind of built-in feature of the Scorpio alarm. Is the only way to just put the bike on a tender to prevent battery draining? (i have no garage)
