Apparently the transmission units are failing so the city cannot read many, many, many water meters.
The first issue is potentially delayed bills which means you may get a future huge bill as it covers multiple bills they couldn't read/send. People cry about this one but they are not over charging, they just skipped bills and then hit you with the total later.
The one that could really suck, you have a new leak you don't know about and now it goes on way longer (more $$$$) as you can't notice it on the bills your not getting!
Take a look at when you paid the last water bill, set the money aside if the next one does not come on time. Maybe check your meter when not using any water to make sure....
Thousands of Toronto utility bills impacted due to failing water meter transmission units
The City of Toronto will be replacing all of its water meter transmission units (MTU) after roughly 141,000 devices unexpectedly failed, causing some customers to receive utility bills that are double or even triple what they’re used to paying.
www.cp24.com
