Fuel tank lining
Boostin
Active member
I've got a tank I've sectioned off for a methanol tank with my ****** flux core welding skills, I need the insides of both tanks lined just to make sure I get no pinhole leaks, does anyone in the gta do this? Called a few radiator shops and no one does it.
i bought a kit from KBS when I built my gas tank (also used a buzzbox for it). IIRC it was 80$ or so for the kit. I would totally use it again.
it is a 3 part kit. first part is the degreaser/cleaner, second is an acid etch, and third is the epoxy sealer. if you followed their directions to a T as I did, it was easy to do. I even scoped it after it was all said and done to make sure it was even coverage and no holes, and it was good.
https://www.kbs-coatings.com/cycle-tank-sealer-kit.html
Barton Rad in Hamilton- 905 522 6126
Ask for Bill
http://www.bartonradiatorworks.com/en/radiator-service.html
Yeah he said he'd do it, not sure if it will stand up to methanol though so going to call me back..
I've seen them all, por15, caswell, redkote, kreem, kbs, they all bad mouth eachother and I read mixed reviews, I'd rather have someone do it that does it everyday
