rbjeepthing
Price:
- $80 firm
- Used twice
- All fittings and tubes are there and in like new condition
- No longer required
- Barrie/Toronto
- PM
- Text 705-333-2559
- Precise four channel vacuum indicator designed specifically for intake synchronization of engines with multiple carburetors or throttle bodies (maximum vacuum rating for this tool is 40cm Hg)
- New mercury-free design uses non toxic manometer fluid
- For use with any 2, 3 or 4 cylinder four stroke motorcycles
- Spill proof design means the tool can be stored in a horizontal or vertical position
- Easy to read scale for precise synchronization
- Unaffected by barometric pressure changes
- Includes hang hook to clip onto the handlebars for easy use
- Rugged, impact resistant ABS enclosure with convenient storage area for adapters
- Rubber feet on enclosure bottom helps prevent sliding
- Includes manometer fluid, hoses, 5mm adapters, in-line restrictors and instructions
- 5mm adapters are used on many Honda and Suzuki models
- Optional 6mm adapters are available for use on most Yamaha models
- Most Kawasaki models do not need adapters
- Patented design
- Accessories; 08-0168 6mm short adapters(set of 4); 08-0013 5mm brass adapters(set of 4); 08-0040 6mm brass adapters Yamaha (set of 4); 08-0014 replacement hose set, 08-0426 Restrictor Jet (set of 4)
