F.S. Yamaha R1 & R6 YEC Parts
woodzee
Bunch of Misc. R6 & R1 YEC parts For Sale. All items are brand new in packages unless other wise noted. Paypal accepted but please add the 3.5% fee.
******'99-'02 R6******
USED KIT RACE HARNESS
Used Kit harness 5MT-82590-70 ('01-'02) removes unnecessary wiring circuits and has a ignition timing adjustment switch (used with kit ECU). This harness can be used with stock ECU. $150.
http://i427.photobucket.com/albums/pp358/Woodzee16/99-02 R6/B-43.jpg
******'03-'05 R6 ('06-'09 R6s)******
KIT YEC HEADGASKETS
Stock thickness is 0.60mm These bump compression slightly.
0.50mm thickness gasket (5SL-11181-80) - $40 each
0.55mm thickness gasket (5SL-11181-85) - $40 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7146.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7147.jpg
KIT YEC FORK SPRING SET
5SL-C3141-85 YEC Fork Spring 0.95kgf/mm - $65 per set.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7143.jpg
FRAME & ENGINE PROTECTOR SET
1 - 5SL-C117G-70 YEC Frame & Engine Protector - $75.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7142.jpg
******'06-'07 R6 (non s model)******
KIT YEC HEADGASKETS
0.50mm thickness gasket (2C0-11181-80) - $40 each
0.55mm thickness gasket (2C0-11181-85) - $40 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7150.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7151.jpg
KIT YEC TRANSMISSION
(**FITS '06-'11 R6) Offers different ratios than stock Transmission. To order new these are $4500 + !!
"A" set $1500 ...includes:
2C0-17402-70 Drive Axle
2C0-17411-80-A0 Axle Main
2C0-17121-80-A Gear 2nd pinion A
2C0-17131-80-A Gear 3rd pinion A
2C0-17151-71-A Gear 5th Pinion A
2C0-17161-70-A Gear 6th Pinion A
2C0-17211-80-A Gear 1st Wheel A
2C0-17221-81-A Gear 2nd Wheel A
2C0-17231-80-A Gear 3rd Wheel A
2C0-17241-80-A Gear 4th Wheel A
2C0-17251-71-A Gear 5th Wheel A
2C0-17261-71-A Gear 6th Wheel A
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7152.jpg
"B" set $1500 ...includes:
2C0-17411-90-B Axle Main
2C0-17121-90-B Gear 2nd pinion B
2C0-17131-71-B Gear 3rd pinion B
2C0-17151-80-B0 Gear 5th Pinion B
2C0-17211-90-B Gear 1st Wheel B
2C0-17221-90-B Gear 2nd Wheel B
2C0-17231-70-B Gear 3rd Wheel B
2C0-17241-70-B Gear 4th Wheel B
2C0-17251-80-B Gear 5th Wheel B
2C0-17261-80-B Gear 6th Wheel B
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7153.jpg
**Plus First kit transmission gets a free Tran. Maint. set a $75 value. Good for three rebuilds.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7140.jpg
******'08-'10 R6 (non s model)******
KIT YEC FRONT FORK SET
Kit includes fork springs & Spring seat & spacers.
Part # 13S-C3151-85 (10.0 N/mm) $125.
Part # 13S-C3151-80 (10.5 N/mm) $125.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7141.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7145.jpg
KIT YEC AIS PLUG
Used to block off the Air Induction System comes with all required plugs. $40
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/ForSale288.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/ForSale289.jpg
****** '02-'03 R1 *******
KIT YEC HEADGASKETS
*Stock thickness is 0.60mm*
0.55mm thickness gasket (5PW-11181-75) $40 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7121.jpg
****** '04-'06 R1 ******
KIT YEC HEADGASKETS
*Stock thickness is 0.40mm*
0.35mm YEC "skinny" head gasket (5VY-11181-80) $40.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7123.jpg
BASE GASKETS
*Stock thickness is 0.20mm*
0.15mm YEC "skinny" base gasket (5VY-11351-80) $40.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7129.jpg
****** '07-'08 R1 ******
YEC KIT TRANMISSION "A"
Comes with:
1 - Part # 4C8-17411-70-A 1st Pinion (Axle Main A)
1 - Part # 4C8-17121-70-A 2nd Pinion
1 - Part # 4C8-17131-AA 3rd Pinion
1 - Part # 4C8-17151-70-A 5th Pinion
1 - Part # 4C8-17161-70-A 6th Pinion
1 - Part # 4C8-17211-70-A 1st Wheel
1 - Part # 4C8-17221-70-A 2nd Wheel
1 - Part # 4C8-17231-70-A 3rd Wheel
1 - Part # 4C8-17241-70-A 4th Wheel
1 - Part # 4C8-17251-70-A 5th Wheel
1 - Part # 4C8-17261-70-A 6th Wheel
1 - Part # 4C8-17402-70 Drive Axle Assy.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7139.jpg
$1,500.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7132.jpg
KIT YEC HEAD & BASE GASKETS
Comes with:
1 - Part # 4C8-11181-80 Cylinder Head Gasket (0.35mm Thickness)
1 - Part # 5VY-11351-80 Cylinder Base Gasket (0.15mm Thickness)
$80
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/ForSale284.jpg
YEC KIT SHORT STROKE THROTTLE
Part # 4C8-C6300-70 Throttle Set $425.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7131.jpg
YEC SLIPPER CLUTCH ADJUSTER SET
Part # 4C8-A6377-70 This kit allows adjustment of the back torque limiter (Slipper) And comes complete with nut a shims to adjust the slipper pressure.
$70.
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/100_7133.jpg
YEC KIT FRONT SPROCKETS W/ Nut (Fits '98-'11 )
17 Tooth Front 520 Sprocket with nut. $30 each
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/ForSale285.jpg
http://i427.photobucket.com/albums/pp358/Woodzee16/YEC/ForSale286.jpg
If interested please send pm..
Parts located in Courtice, Ontario (just east of Oshawa)
Thx.
Couple of Gaskets SOLD ! and one item pending !!
Cams and a bunch of headgaskets SOLD!!! Lots of misc. goodies remaining see updated original post !!!
