Hey guys, Thinking of doing a coolant flush. Is Engine Ice the good stuff ??
Lol, All I wanted to do was just a normal coolant flush. for street riding, no track, no crazy drag strips. Just wanted to "spring clean my bike" I guess.
But I never done a coolant flush befor on my bike, and looked at the first Youtube video and the dude was using Engine Ice. So I thought I would ask if that's what to use, or a diffrent brand?
I thought we agreed you were going to turn it into a spec drag racer with Honda civic cams for vtec, nitros, decals and your own meme series.. no? Well this has made my summer disappointing
is there anything that's ok for the track but won't freeze in your bike over the winter??
All glycol/water mixtures perform about the same in terms of heat transfer and heat capacity regardless of claims or brand name. The difference is the additives and material compatibility - and that can be a major one. Coolants using so-called OAT or HOAT "organic acid technology" - often called "extended life coolant" - must not be mixed with standard coolants.
There's nothing to be gained by changing to anything other than what it says in your owner's manual.
Keep in mind that if you are doing a track day or racing, glycol-type coolants are generally not allowed (and the organizations that do allow them, shouldn't). Water and WaterWetter (corrosion inhibitor - NOT glycol antifreeze) or equivalent only. There have already been huge discussion-wars on this forum about that ...
