Dayao12
So here's my situation.
(A) When I try to start my bike, it cranks, but there seems to not be enough juice to get it going and it slowly dies out.
What I've tried:
1. Fully charge battery over night - Starts fine. But as soon as I turn the key off after a ride, same issue from (A).
2. Push start gets it going but same issue from (A) when I turn off the engine.
3. Tested batt with Voltimeter.
Bike off: outputs 12V
When starting: Drops to 8V
Observations:
Horn and front brake light trigger does not work.
Everything else works fine! Lights, high beams, rear brake light...
Battery doesn't seem to have any fluid left. Would that help if I filled it up?
What are your thoughts? What else can I try?
What I've tried:
Observations:
