bombshelter13
I adjusted my clutch the other day because I suspected it was sticking slightly. My initial adjustment was off slightly: after a quick ride around the neighborhood, I noticed it seemed to be slipping slightly when accelerating past 30 MPH... so, I pulled over, pulled out my tools, and did a second adjustment - loosening it a bit at the release mechanism, so that the clutch was more engaged in it's resting position.
After the second adjustment, everything seemed pretty good, most of the bike's behavior seems correct, except one thing: If I chop the throttle slightly in an attempt to cause engine braking, the rev's drop a lot slower than they did before the adjustment - instead of getting immediate engine braking, the rev's seem to slowly fall back downwards, slowing down the bike's forward motion very gradually instead of getting good engine braking.
Now, it's possible that these might not actually be related and might have just coincidentally happened at about the same time, but I'm wondering if maybe I need to do a third adjustment. Thing is, I'm not really sure whether this behavior would be caused by the clutch being too tight or too loose.
So... if this slow rev dropping is related to my clutch adjustment, it too loose or too tight?
NOTE: When I talk about loose and tight, I'm not referring to the lever end, I'm referring to the release mechanism - i.e., when I say tighter, I mean the release mechanism is applying more pressure to the clutch pushrod when the cable's in it's resting state (clutch more disengaged by default). When I say looser, I mean the release mechanism is applying less pressure to the clutch pushrod with the cable in it's resting state (clutch more engaged by default, less maximum disengagement when lever is pulled)
