Freak
I have a GS500F 2008. The magneto gasket which is after the sprocket section had a leak, so finally after a month of leaking and topping up i decided to change it. It took me a few hours to do everything as this was my 1st time changing oil and gasket. So i drained the oil, took out the filter and then took out the sprocket cover and then the magneto gasket cover, scrapped the **** out of the old gasket, replaced it with a new one, tightened all the screws, put the spocket cover back, put the new filter in and screwed all the bolts and nuts. Topped it up with oil and now the bike wont start. I hear a loud spinning sound by where i replaced my gasket. The bike will bump start but then if i turn it off it goes back to its original condition. I didnt play with any wires etc, cant remember anything except putting a cog which moved out when i pulled the gasket cover off. Any idea what can that be? I am essentially stuck at work around yonge and stclair with this problem. HELP!!
