Brembo Ladybird Brake and Clutch Stays with reservoirs | GTAMotorcycle.com
OMMRA
New. $40
Ladybird stainless steel clutch stay and 15 ml Brembo racing clutch reservoir tank.
The most elegant way to mount your reservoir tank!
A very ingenious solution created by Ladybird parts:
  • Laser cut high quality stainless steel (not aluminum, which can break with fatigue)
  • Stainless steel properties mean it will never crack or break
  • Can be carefully bent to any desired position
  • Extremely light and elegantly crafted
For all RCS Brembo Racing radial clutch masters.
1 x Ladybird laser cut stainless steel clutch stay
1 x stainless washers
1 x stainless 6mm bolt
1 x 15ml Brembo racing clutch reservoir tank (10.4446.40)
SET UP FOR USE WITH BREMBO CLUTCH MASTERS ( RADIAL)
PLEASE BEND THE STAY IF NEED TO ACHIEVE THE DESIRED POSITION(THE BEAUTY OF USING STAINLESS STEEL!)
PM works best
ttt
